Tool for cutter the steel wire of SWA cable
For an indoor gland lovely any standard above domestic installation maybe not so much. I’d like to say junior hacksaw no matter the size of swa a be aware of a new blade as occasionally you can cut slightly deeper when ringing.
When attempting a few metres stripping back I like to unravel all swa in one it leaving 200 to 300 and cutting the excess. Then becomes easier to remove 1-4 steels at a time to have a nice end when needed with certain cheaper glands.
Ringing the swa with a junior hacksaw is an art but feeling comfortable or naturally doing it is something else. Forming the swa in the certain angles and positions will also help giving you a precise connection between the olive a cone. This with larger swa’s will end up landing the cable into position with minimal resistance. Repetition, trial and error and lot of practice is probably unrated.
For a larger swa when you only get one gland in a pack bw, cw glands are suspect. E1w from cablecraft I’ve found don’t mix metals (comes with a brass nut), a ip washer (fibre washer will give you the same outcome but fibre washers deteriorate in harsher environments) also a brass screw for tapping the swa bond into a gland plate, jb, cabinet, board.
Tools needed
-Knipex cobra adjustable wrench x2 250mm long will do to a 32mm maybe 40 (less chance of damaging the brass which wouldn’t pass compex or Atex gland inspections when being assessed) believe it or not tend to be more handy than expected only have a 160 set knipex cobra grips in my bag now.
-Stanley
-Junior hacksaw
Enjoy lol
Tony / Jointech. I saw it and thought the same, just expanding on the blade runner/pipe cutter principle. 🤘
No idea what the blade runner is, but this will handle any size cable from 25 up. No frequent replacement of blades and needs only a 1/4 turn back and forth. Simple and very effective, but surprisingly no one previously thought of using it.
Old thread.
I’m sure everything has been suggested before, but good to carry on the conversation.
It hadn't been, hence my response to this resurrected thread. There are only a small number of new posts, so it won't take long to read them and determine whether they hold any relevance to the work you do.
I have the blade runner and armourslice, I must admit while both are very useful tools, I don't use the blade runner much since I bought the armourslice and that only really comes out if I can't get a junior hacksaw in, most of the time I just use a saw as it saves me having loads of extra kit to lug around!
Sy
You didn't list Tony's exhaust cutter which works like a dream on sizes other products won't look at, right up to the biggest of cables, and doesn't need new blades at regular intervals. For small cables, a hacksaw cuts through armour faster than you can set up an armourslice.
I thought one was missing but had a complete brainfart
Hacksaw
TLC Blade Runner - Bladerunner SWA Stripper - Bladerunner SWA Stripper - https://www.tlc-direct.co.uk/Products/KTWSBR28.html
CK Armourslice - Armourslice SWA Cable Stripper : Carl Kammerling International - https://www.ck-tools.com/products/ck-tools/armourslice-swa-cable-stripper/
Plumbers Pipeslice - Hand tool set with TC 35 and TC 42 in ROBOX | Pipe cutters - TUBE CUTTER 35 | Pipe cutters - https://rothenberger.com/gb-en/pipe-cutters/pipe-cutter-tube-cutter-35 (versions also for INOX/Stainless)
Grinder
Handheld Bandsaw
Exhaust cutter - Sealey Exhaust Pipe Cutter | Halfords UK - https://www.halfords.com/motoring/tools/garage-equipment/head-gasket-and-exhaust-repairs/sealey-exhaust-pipe-cutter-453390.html
That Sealey cutter looks to be a terrible design for the purpose of cutting armour, not to mention its frightening price. This link, coupled with your prior 'brain fart' could lead one to believe you don't want people knowing about this wonder tool 😁
Increase pressure gently. It's the same kind of pressure used when cutting 8mm copper
The strands snap off cleanly.
JuniorSparky,
nicebutdim,
