tool required | on ElectriciansForums
Discuss tool required in the UK Electrical Forum area at ElectriciansForums.net
How do,
Can anyone identify these accessories? I need to get hold of the tool required for removing screw heads
thanks
[ElectriciansForums.net] tool required[ElectriciansForums.net] tool required
that will probably scratch the faceplate. a set of security bits is only a few quid, and you get the torx and allen key ones as well. i have a set to fit any 6mm hex. driver body. about ÂŁ7 from wholesalers or ebay.
if the screwdriver is not a diy finest, then the slot needs to be made with a fine disc angle grinder. have plenty of plasters or insulation tape and bog rool to hand for the sliced fingers.
Reply to tool required in the UK Electrical Forum area at ElectriciansForums.net
I use this one, copy this into a search engine: 200EP Tone Generator Kit High Accuracy Cable Toner Detector Finder Tester with Inductive...
Not this exact one, but something very similar. great bit of kit if you don't like tools bangling from your hips...
