Good Morning. Can anyone tell me what tools would be used when cutting channels into plaster when rewiring an occupied home?
House has solid walls, not plaster board and electricians used jackhammers to channel out, without extraction. I know rewiring is messy but the house was like a building site.
Is this usual practice? I have been told that electricions have cutting tools and use extraction and have had a previous house rewired (solid walls) and can’t remember this level of mess.
thank you.
Moved a socket for a client last week well after he’d started decorating. Minimal dust but it was just one back box. He texted me last night wanting another one done! I texted back saying that he was supposed to do the messy stuff first! His response was ... ‘tell me about it!’ Very understanding with expectations managed. :p
Ha yes and I didnt know how to edit it. And the house is occupied.
I don't think most small one man bands have wall chasers and dust extraction, I don't. I would make a lot of mess when re-wiring a house but I would have a tidy up each night with regards all the plaster/brickwork on the floor. I would cover all carpets with a dust sheet, but there would still be some dust that penetrates. Even if the house was not lived in during the rewire I would still clear up (to a degree) all the mess so that the next day I don't return to a bomb site as this is horrible to work in. If it was lived during the rewire (nightmare) I would have had a chat with the homeowner before hand about the degree of cleanliness that is required each night after finish of work.
Have a chat with the electricians and ask them to clear it up, I expect they will.
Ps.. That is extremely messy though!
Really? I would expect most to have it, I know I certainly do and have had since I started up on my own many moons ago.
Depends if you’re doing lots of rewires. I did mainly refurbishments, like kitchens. Most of which were gutted, so I used angle grinder, vac and opened the windows, and kept the doors shut. Sometimes I had to take a break to let the dust settle.
Mind you, if I was a younger man, I would of bought one of those Metabo ones.
I just stitch drill carefully then use a 40-50mm SDS chisel when chasing, I think using any kind of disc cutter in an occupied home is just ridiculous, the dust is horrific.
We clean up after every chase by brushing up all the larger mess first then vacuuming and you can keep it well under control. It also helps to take as much as possible out of the room being worked in and cover everything else thoroughly. In some places it can end up cleaner than before you started. :grinning:
You stitch drill every chase ? Would this apply to a full rewire and how long would it take you ?
Using a twin disc grinder and a good dust extractor would create a lot less dust than stitch drilling.
I do Andy , but we don't do enough of it to justify the full on kit really. A long chase from the ceiling down to a socket for example would take no more than half an hour with the box sitting dead flush and even with the twin disc chasing tools you still have to chop out the bit in between.
[automerge]1582138445[/automerge]
But you still have to chop out the bit in the middle.
Doesn't have to cost loads at all. My chaser was £99 from screwfix and works well enough with my Henry clone vacuum. Little bit of dust on the plunge and then almost dust free grinding. The middle flies out with a sds chisel after grinding. Probably 5 mins per chase.
Worth trying out for £99.
You may be right, I guess it depends on how many rewires you do per year. I do 1, sometimes 2.
I have a twin disk wall cutter that I bought from Aldi for £60 about 3 years ago, and a Henry. I do anywhere from 4-10 domestic rewire's a year and it's still going strong apart from New disks it owes me nothing and has saved me months of tedious work!
uk
Tools used when rewiring domestic property.
Domestic Electrician Forum
BALDRICK,
radiohead,
