Top Electrical Tips! | on ElectriciansForums
Discuss Top Electrical Tips! in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Silly Sausage
Viz stylee....
Use your ammeter to find the current rating of fuses and mcbs when the numbers have been rubbed off.
If you're a DIY'er installing your new 18kW shower the existing 2.5mm cable is fine and it will also now double as a towel heater and mirror demister.
Mount control panels, enclosues, joint boxes, trunking and traywork by eye with tilted head, so that water runs off them more easylierly.
Cables in panels don't need to resemble rainbows... stick with one colour like black... and don't let numbering spoil the look.
Schematics in panels are fire hazards, remove them to the nearest bin.
In wet areas, panel fan inlets should be low down, sucking in without filtration.
Reply to Top Electrical Tips! in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Thanks, P. I’m trying to make my Caravanning holidays less stressful as well as less physical…. It’s the hand pump that came with the awning, and...
AVR's and Generators in a rack??? And only at 7.5kW?? What are you actually trying to build?
