Top floor lighting gone - fuse replaced, still no action. | Page 2 | on ElectriciansForums
Discuss Top floor lighting gone - fuse replaced, still no action. in the UK Electrical Forum area at ElectriciansForums.net
King's Lynn
Hi,
As per...the top floor lighting is all gone - i've tested and changed fuses on every part of the box and I cannot get the lights back on.
Bulbs changed for ones I know 'work' too.
What has happened?
(if wrong forum sorry)
You have all the lights working now?
What did you do?
I had no concept that those 'three' red wires must be looped touching each other all the time, i prised a bit away to fit it in the rose fixture, it won't fit as is. nightmare, naĂŻve of me but i've learnt something...i started the day replacing the kitchen fixture but the connections are modern so simple, this is horrid
It's a bit of a cultural thing. The wiring you have is a standard "British" arrangement, used from around 1960 until fairly recently.
Most decorative light fittings are made for "European" wiring, where it's unusual to have any more than one cable going to a fitting.
Most electricians in this country seem to have moved towards this single cable to the fitting now, with the loop in and out often moved to the switch instead.
Now that you've fitted the new light, no wires must be left just twisted together.
Reply to Top floor lighting gone - fuse replaced, still no action. in the UK Electrical Forum area at ElectriciansForums.net
By the looks of it the whole head comes off in one unit, guess it has a driver inside of it. Ive tried to Google the Image i have, one comes up...
Our house in a row was built in 1971 and we have metric cables with cpcs for the lighting, top of the row imperial and no cpcs.
