Torque screwdriver !!!!! | Page 2 | on ElectriciansForums
Discuss Torque screwdriver !!!!! in the Electrical Tools and Products area at ElectriciansForums.net
I bought an armeg one out of impulse after saying they are pointless and I can now confirm that the are pointless rarely ever comes out of the van
I have a wera one. There interchangeable bit set works well on Hagar and SBS, slips on BG though when approaching the required torque but thinking about it most drivers slip on the BG screw heads
I’ve got a torque screwdriver and two torque wrenches. All of them bought for doing various mechanical jobs on the landrover.
I’ve used a torque wrench for bolted connections in a panel board a couple of times, but never for small connections at a DB or CU.
There are times when correctly set specific torque is important, but not in the work most of us are doing on a daily basis.
My big objection to the use of torque screwdrivers is the lack of knowledge of how to use and look after them correctly.
Nice... Only time I use my torque wrenches is on me Motorbike as I'm delving into mechanical territory :)
Just bunged an email to Armeg to see if they are aware of this thread. In general I love their kit, been using their wood beavers which are very effective for going through joists.
No-one was saying it was hard! Just wondering if people have been asked to show them for inspections. After 30 odd years Ive never had any issues and played with all sorts of switching gear up to and including 33KV. :)
Sorry never ment to come across as a dig ☺I was having ago at the silly regulation
We are registured with NIC and its never come up during their inspections
I always use a torque driver, have an armeg and an wiha set, if the manufacturers of DB's state that a torque driver should be used then surely that is what we should do, I have wrecked many an armeg blade and the wiha one normally rips ---- out of terminal screws but hey ho!
I always use a torque driver, have an armeg and an wiha set, if the manufacturers of DB's state that a torque driver should be used then surely that is what we should do, I have wrecked many an armeg blade and the wiha one normally rips **** out of terminal screws but hey ho!
Do any manufacturer's instructions state that a torque driver must be used ? I have seen lots that state recommended torque values but not how they are to be achieved.
Okay they don't say you are to use a torque driver but how else are you going to achieve it, being devil's advocate here we all bang on about how you mustn't mix manufacturers mcb's, what is the difference between torque settings and pick and mix mcb selection, is one worse than the other?
I'm sure I'm capable of tightening something up without a device to tell me I'm there. I have measured my usual connections against a torque driver many times and my wrist seems to be calibrated ok. I'll keep checking at regular intervals though.
Cards on the table, I'm not against torque drivers on principle, but I am against the way they are being advocated as the be all and end all of cable termination these days.
It seems that the use of torque drivers is being brought up regularly, but they are only any use if the basic techniques and skills of cable dressing, prepping, terminating and checking are adhered to. Try it yourself. A badly terminated cable is easily pulled out even if tightened with a torque driver.
It all seems a bit like non combustible consumer units to me, a method to try and patch over falling standards without addressing the system that is producing the hazards that necessitate these patches.
…...and another money making method, jumping on the bandwagon of said 'falling standards'...…...of both quality of work and materials.
Perhaps someone should tell the colleges and training centres. All the screw heads and treads on their kit always seem stripped to bits.
Reply to Torque screwdriver !!!!! in the Electrical Tools and Products area at ElectriciansForums.net
Bought some just for that purpose ...... but never been asked to show them :(
You can buy the wera ends in singles for replacing broken and worn ends which is nice
