As far as I know, the other problem with them is you have to have them calibrated. I do't know hoe often, who does it, what it costs, or even if it is true. I also heard some schemes are asking to see them and their calibration certificate.
I used one once on a job for someone who had one, and I was surprised how tight the manufacturer's stated torque for the MCBs i was using was.
I would like one, because I am a tool junkie, but I can't justify the price.
However, I just broke another bit from my WIHA slim vario set today to go along with the other lost and broken ones. I might get the WERA ones next, but it won't be the torque ones.
I had the torque setting in my wrist, elbow and ear synchronised and it works perfectly!
Does anyone use one then? I have a 3 foot torque wrench somewhere that i use when i'm pretending to be a mechanic, in reality it ended up living next to the drivers seat of my vauxhall nova.... just incase.
try facom, there protwist (red vde) drivers are stronger.
wera are softer than wiha drivers
As far as I know, the other problem with them is you have to have them calibrated. I don't know how often, who does it, what it costs, or even if it is true. I also heard some schemes are asking to see them and their calibration certificate.
I used one once on a job for someone who had one, and (and or comma, not both) I was surprised how tight the manufacturer's stated torque for the MCBs i was using was.
Let battle commence.
If you do the neutral bar or earth up as much as it states 3nm, then it snaps conductors very easily, I do own one, but would rather just use my head.
Marvo, keep out of things you don't understand. Spelling and grammatical correction is MY JOB.
:hammer:
Got ya you nappy wearing little Grammar ----:grin:
Calibration would normally be specified after a certain number of uses rather than a specified time period. Also they should be checked against a reference unit on a regular basis.
And being reliant on springs etc for their accuracy they should always be set to their lowest setting when not in use and stored/used at the specified operating temperature.
Wirral
Business Name
Farm electrics
torque screwdrivers
Talk Electrician Forum
Thread Tags
Farmelectrics,
Geordie Spark,
