M
mep
Hello,
I know this is an electricians forum...which I am, but I have a problem with my boiler. I ran out of oil and have now replenished it but it won't come out of lock out mode. Every time I try to reset it, it fires up for a couple of seconds then goes to lock out. I understand that I need to bleed/prime the oil pump and I have tried to undo the brass nut but cannot budge it - this is the outgoing line from the oil pump which has a rigid pipe connected leading to the brass nut and screw. Does anyone have any suggestions please? It is a worcester 15/19 boiler and the pump is danfoss BFP 41 L3.
Thanks,
Lisa.
Thanks,
Lisa.
