- Joined
- Jan 21, 2011
- Messages
- 581
- Reaction score
- 34
hi guys
Been asked to add a towel rail in bathroom) via SFU off a new ring main i have just installed.Obviously new ring main is protected by 30mamp RCd but the existing lighting circuit has no RCD protection. Main bonding is in place, continuity of pipework established and the circuit (ring main has 30mamp RCD) so requirements are met for the addition. My question is regarding supplementary bonding and the existing lighting circuit. Will i have to install supplementary bonding for my addition to comply, due to the lighting circuit having no RCD protection even though this is an existing circuit/situation. The regs state all circuits but i am uncertain if this is to be applied to the existing installation.
Just to add the bathroom is currently stripped so not sure if there will be any extrenuous pipe work to bond (may be plastic) all class2 light fittings at a height of 2.5m as will be the SFU for towel rail
many thanks
many thanks
