TP Fan Isolator in Shower Room | Page 2 | on ElectriciansForums
Discuss TP Fan Isolator in Shower Room in the UK Electrical Forum area at ElectriciansForums.net
Midwest
Nearly Esteemed
Oxfordshire
Went to look at a job yesterday, shower room refurbishment. I'm just replacing the existing main light, vanity mirror and dual fuel towel rad. No RCD protection on lighting, but as I'm just replacing what's there, I consider that just maintenance.
There is also an extractor fan, located outside just outside zone 2 (appears suitable for outside zones). Unusually, the TP isolator (plate switch) is located next to fan (I normally install isolator outside bathroom). I'm only removing fan & isolator, so the wall can be tiled, then re-fix. I've checked OSG, and plate switches can be installed in bathrooms outside zones, but still not 100% happy. Thoughts?
PS; I 've seen several threads debating such, where in the case of a short circuit, it's odds & evens as to which would go first, whereas in the case of an overload, the 3a 1362 would go first. Now I'm not clever enough to say if that's correct or not?
Let the debate begin.
Previous fun tests with workshop B32 rfc and s/c at plug ( :rolleyes: ) resulted in both fuse melt and mcb trip for 13A and 5A fuses, but 3A fuse blew fast enough to discriminate and B32 mcb didn't trip. Actual results may vary, sample size 1 ... :)
The 3A fuse rating got snagged on an NIC inspection a few years ago, when wiring new builds now we always wire the bathroom lighting on its own circuit protected by a 3A MCB, I'm sure that I've seen an isolator with a fuse carrier hat someone manufactures though.
Last seen somewhere in China.
Best place for him....;)....(I do miss those TT and neutral in switches keyboard scraps though)
I wonder if it ever went up in smoke you'd be in trouble cos it states 'fuse' not mcb!
Does anyone actually fit a switched spur at fan,I doubt it
We use certain manufacturers fan on jobs & insists on 3amp fuse in destructions, spoke with them about it they will invalidate any claims if it is not installed correctly.
Have been using another brand for continuous running if this fed from 6A light circuit it is fine in the instructions.
We sometimes run a bathroom & ensuite from 3 C/B on the board or if we have quite a few rooms with fans use 6amp C/B in board & sit a grid switch above with a bank 3 amp fuse units mainly if large house & the D/B is in a cupboard.
I've replaced a few fans, which have either been jammed up with bird nesting materials, or like the last one, a wasp nest. None had had a local 3amp fusing, and as far as the owners were concerned, had caused the circuit mcb to trip. None had started a fire, or had signs of thermal damage.
That said, if the instructions say fit a 3amp fuse, that's what I'll do.
Reply to TP Fan Isolator in Shower Room in the UK Electrical Forum area at ElectriciansForums.net
I recommend the Manrose Humidistat timer: Humidity Sensors for fans -...
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
