TRAC timers?? | Page 3 | on ElectriciansForums
Discuss TRAC timers?? in the UK Electrical Forum area at ElectriciansForums.net
K
Kev2632
Hello i was wondering could explain to me what the information means on the number 2 output means?? and is number 2 and 1 the option of having two outputs on the timer?? thanks
[ElectriciansForums.net] TRAC timers??
I think that you are correct , yes.
The timer is designed so that with live to 3 and neutral to 4 the timer function will operate.
If the link described in the instructions is not present then there will be no voltage on 1 or 2 at any time.
However there is an internal switch that joins 1 to 2 when the timer is on, this is electrically independent of 3 and 4.
If the link between 2 and 3 is in place then there would be 230V at 2 all the time and this would be connected to 1 when the timer is on.
Thats magic, I understand that perfect now, thanks soo much for your help, I wish everybody was like you in this day and age. Thanks again
Reply to TRAC timers?? in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
That doesn't make sense it is a completely new timer so needs connecting as per the instructions for this unit. Has the safety cut out on the...
