Tracking from another electrical socket. Is this ok? | on ElectriciansForums
Discuss Tracking from another electrical socket. Is this ok? in the Australia area at ElectriciansForums.net
dprovan
Hi all,
I am hoping that someone can put my mind at ease. My friend who is a builder, not an electrician, said he would fit a new electrical socket for me. I needed a new single socket in my kitchen. He tracked a cable from my utility room washing machine socket to the kitchen apprximately 20 cm along the wall and 20 cm up the wall and then through the wall into the kitchen.
He had no plastic coving for the cable so wrapped it in insulating tape and told me to pollyfilla the cavity, when I asked if it would be ok without the plastic casing he said it would. It is encased in an internal solid wall.
Now, I imagine that the cable should be in plastic casing but is this ok/safe.
thank you
Running the cable across from another socket is ok, as horizontal or vertical route from another outlet is within the correct zone. Sounds like where he chased up the wall before drilling through may be in the incorrect zone.
He can only spur from the existing socket if it is on the ring final circuit and not already a spur or if it is on a radial cicuit.
The cable size should have been 2.5mm2 and the cable he used sounds asthough it should be rcd protected at the board if not already protected by this.
Kitchen is also classed as a special location so works should have been certified and notified.
Cable does not require plastic casing if hes used sheathed cable, Cant see why he has wrapped the cable up in insulation tape...... (has he used single insulated wires or a 3 core cable?) Ive got lots of friend in different trades but i wouldnt trust half of them with electrics.
Jst to be on the safe side get yourself a sparky friend and ask him to inspect it
thanks goldie, not sure what it is best I can do is decribe it. Grey thick cable quite rigid in feel. When I cut into it there is a blue and brown cable seperated by a copper cable. Hope this helps
murdoch i would not know what RCDs are or how to recognise them. Likewise I dont know what a ring, radial or spur are or how to identify which it is
Could you post a picture of your fuseboard? That would help regarding the RCD. As for the type of circuit its more dificult to "identify" without taking a look really.
I am based in N Ireland (Ballymena)
Here is a photo of the fusebox, hopefully you can see it ok
[ElectriciansForums.net] Tracking from another electrical socket. Is this ok?
hi
the first photo is the tracking along and up the wall. From there is just goes to the other side of the wall where it connects to the new switch in the kitchen.
The second photo is a closer look at the cable.[ElectriciansForums.net] Tracking from another electrical socket. Is this ok?
  • [ElectriciansForums.net] Tracking from another electrical socket. Is this ok?
Reply to Tracking from another electrical socket. Is this ok? in the Australia area at ElectriciansForums.net
Sure, I'm on the Isle of Sheppey. also the cable they used I think was 2.5 twin and earth, although I could be wrong.
What type of car have you got/ordered ? I use a portable charger, can charge as low as 6 amps and the car's maximum is 26 amps. I have a number of...
