Discuss Transformer/power supply required - difficulty in finding in the Electrical Appliances Forum area at ElectriciansForums.net
Thats great - many thanks for this - that'll make the splice job easier!As per Rockingit, if you buy any 24V (0.1A or greater) adapter with a flying lead on it, you could put the appropriate in-line socket on it.
e.g. 2 pin DIN Socket Speaker and HiFi Connector Screw Terminals Strain [2 Pack] - https://www.kenable.co.uk/en/audio-/din-cables-adapters/din-to-din-cables/11291-2-pin-din-socket-speaker-and-hifi-connector-screw-terminals-strain-2-pack--5054338112916.html?
Available from many sources on the web.
I know the Chinese 'Christmas light' connectors often do not conform to DIN dimensions, but suspect the above should work!
Make sure you connect it the right way round, the +ve to the round socket and the -ve to the blade socket!
I think thats what i'm going to do - thank youHave just realised that you may be referring to the output connector - you may have to change the plug on the end of the device cable but that's rarely a big job. You can also get PSU's with multi-changeable outlets, too (search within that link).
ooh - perfect and hacksaw - yes indeed.This is almost exactly the right thing, but there's a shroud around the socket that might stop your connector from plugging in! Hacksaw?
KWONG MING IKEA 24 VOLT DC FAIRY LIGHT AC-DC ADAPTOR KMUV-240-030-BS (K 390) | eBay
Find many great new & used options and get the best deals for KWONG MING IKEA 24 VOLT DC FAIRY LIGHT AC-DC ADAPTOR KMUV-240-030-BS (K 390) at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
PS is it an IKEA lamp?
Forget the hacksaw!ooh - perfect and hacksaw - yes indeed.
No the lamp is from coopers direct model 6049.
many thanks for your help again.
Ah - even better - many thanks once again.Forget the hacksaw!
Just saw this one from the same supplier, capable of slightly higher max. current output, which will still be fine.
TDC POWER 24 VOLT DC FAIRY LIGHT TRANSFORMER / ADAPTOR DB-2.4-24D 35/9 (T1140) | eBay
Find many great new & used options and get the best deals for TDC POWER 24 VOLT DC FAIRY LIGHT TRANSFORMER / ADAPTOR DB-2.4-24D 35/9 (T1140) at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
Reply to Transformer/power supply required - difficulty in finding in the Electrical Appliances Forum area at ElectriciansForums.net
