transformers/dimmer | on ElectriciansForums
Discuss transformers/dimmer in the Australia area at ElectriciansForums.net
Z
Zaffy
My dimmer switch servicing six 12volt MR16 went. Pushed it in and nothing happened, no click. Replaced it with new component. Stil did not work. Replaced the two transformers. Still does not work. Any advice/tips before I call in an electrician?
have you still got power to the switch? to be honest, this would involve live working and if you a. are not competent. b, don't have the correct test equipment, then call a spark .
Maybe a neutral, maybe not enough voltage which a "neon" wont tell you, your friend could have killed himself. You are missing plenty of things. Call a electrician in or even post your location on here and maybe someone on here could come and have a PROPER look for you. Shouldn't take too long to resolve the issue.
Reply to transformers/dimmer in the Australia area at ElectriciansForums.net
Try disconnecting the "central heating off" wire from terminal 2 and insulate it (eg Wago connector or choc block or similar) and tuck it out of...
2 3
4K
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
