View the thread, titled "transformers/dimmer" which is posted in Australia on Electricians Forums.
Z
Zaffy
My dimmer switch servicing six 12volt MR16 went. Pushed it in and nothing happened, no click. Replaced it with new component. Stil did not work. Replaced the two transformers. Still does not work. Any advice/tips before I call in an electrician?
assuming that each lamp is 50watts, then you are loading a 105 watt tranny with 150watts a 35-105 tranny should be 1 tranny for 1 downlight.
I forgot to say it is a double dimmer the other half of the dimmer works fine and serves an ordinary lightbulb.
I installed a two gang dimmer yesterday. One side worked fine and the other didn't. After deciding it was faulty, being a qualified sparks I decided to poke it with my (1000v insulated vde) screwdriver.
This is no word of a lie. It sparked, made a popping noise and caught fire. It looked like magnesium burning. I turned it off put a 2g switch on and I'll be going back in the week to replace it.
Call a qualified sparks!!
dimmers, the scourge of my life. should be put with the neons under the hammer.
If I do, I won't be calling you.
Reply to the thread, titled "transformers/dimmer" which is posted in Australia on Electricians Forums.
