Tri-flex instead of solid tails | Page 2 | on ElectriciansForums
Discuss Tri-flex instead of solid tails in the Commercial Electrical Advice area at ElectriciansForums.net
I've used 150, 185 and 240mm trip flex on large installs before contained in metal trunking.
Is there any reason I can't use 35mm for a 100amp 3phase install contained in plastic trunking? Bend radius and access is going to be tricky and a pain with solid core.
Hi guys
I don't often reply to threads,but I have installed all the cables mentioned in the thread on ups and LV panels and I have always used lugs with a hex crimper and heat sleeving.
hi all
install few months back used tri rated in metal trunking nice slot direct above head with protection & no gap, Siemens engineer turned up to make connection & install fuses to the head mentioned they will not connect to tri rated anymore.
think it was bi rated at that size not tri rated 120mm.
this was also a crimped hex lug into the switch fuse installed next to the head & out the RF panel.
Reply to Tri-flex instead of solid tails in the Commercial Electrical Advice area at ElectriciansForums.net
