Tri-rated cable CCC. | Page 2 | on ElectriciansForums
Discuss Tri-rated cable CCC. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Well I think that you have to take BS7671 into consideration when building panels. Doesnt 512.1.5 apply then? This is what you was talking about.
Yes I do work to 60204. I dont want this made into a p**sing contest as im not into that rubbish. I am here to help people and learn.
Spoon,
I wrote a long and detailed post explaining the situation and agreeing with 512.1.5 with regard to the OP, not a p**51ng contest at all, however, the current forum problems deleted it, & I can't be bothered to write it again.
Sorry all getting really fed up with the fact that the forum just will not load on times.
Spoon,
Happens many times to me also. Getting close to giving up posting...
Use firefox browser as i have .... it sometimes hangs a bit when loading post but dosn't crash.. .im using it till DAN's sorted out the bugs
Spoon,
No problem mate.
The only problem I have with this forum is when I use the comp at home. My Google Chrome sometimes doesnt like the site.
Sometimes when I have to write a lot I do it in Word then paste it into here.
Reply to Tri-rated cable CCC. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
https://www.byson.co.uk/uploads/product_pdf/tri-rated-cable_ho5v2-k_ho7v2-k.pdf 70mm up to 259A
My understanding is it's not necessary unless compromising a fire barrier. Hager instructions: Cable Access: Cable access into the metal...
