Tri-rated vs singles | Page 2 | on ElectriciansForums
Discuss Tri-rated vs singles in the UK Electrical Forum area at ElectriciansForums.net
rick
Bedfordshire
Is it OK to use tri-rated cable in conduit rather than singles (6491X)? Obviously of correct rating. If so, why would anyone buy singles as the tri-rated is cheaper and seems nicer to use (I have not used it before until very recently, hence the question).
Cheers
No, tri-rated cable is single insulated flexible conductors.
Thats like asking if you can get unarmoured SWA.
I think bigspark17 was asking about the finer stranded = easier to bend conductors.
Sadly never seen it, I really wish that size above say 10/16mm used 19-strand instead of 7 as cable-wrangling would be a whole lot easier :(
Reply to Tri-rated vs singles in the UK Electrical Forum area at ElectriciansForums.net
On a small generator I wouldn't want to risk using diversity as they are not quite as forgiving as a mains supply and can very quickly fail when...
