tripping induction hob | Page 2 | on ElectriciansForums
Discuss tripping induction hob in the Talk Electrician area at ElectriciansForums.net
Hi guys
Interested in your thoughts here. I recently installed a new circuit to supply an induction hob and oven. The circuit is supplied via a 40 amp rcbo. The rcbo however is intermittently tripping, sometimes when it's not even in use and stone cold I.e no fan etc running. I know the loading is correct and this is not an overload fault.
I'm thinking it's a faulty oven unit/hob unit - it's brand new and straight out the box.
Or do induction hobs require a type c breaker to cope with the inductive load
- if that's how they work? Iv fitted induction hobs before in type b breakers and never had a problem.
Any thoughts?
Thanks.
Dan
Gasp !!!
Reply to tripping induction hob in the Talk Electrician area at ElectriciansForums.net
N
He hasn't provided any certificates, including previous work. He sends invoices when he needs paying.but no vat registration number etc on...
  • Nessab16
  • Ireland
  • 8
  • 649
Nessab16
N
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
