L
LesleyJ
I'll start this by saying I know nothing about electrical things, so need help!
About a week ago the master breaker started tripping, and has done so each day since (though at different times each day). We thought it was the fridge/freezer causing it, as it had been making overly loud noises, so plugged it into an RCD. It is still tripping and we can't work out what is causing it.
Can anyone advise?
Thanks.
to be honest, only an electrician has the means to find the fault. i.e. test equipment and the knowledge to use it. the time you will waste trying to find the fault is better spent on getting a professional in.
Tripping problem
Australia
LesleyJ,
telectrix,
