Having only whipped through this thread,it seems you have no testing to indicate a fault,no fault on existing,connected to correct neutral bar etc and yet it trips the Rcd when its connected?
Somethings amiss with either your testing or your tester or your consumer unit connections
Having said that,split the ring and connect one half at a time and see where that gets you,at least having one half to hold in will get you started
