Tripping RCD | Page 3 | on ElectriciansForums
Discuss Tripping RCD in the Australia area at ElectriciansForums.net
L
lofty84
One of the RCDs keeps tripping in one of the propertys we are working on. The RCD supports the ring in the kitchen, lights and doorbell from what I can remember. when we put the ring on the other rcd in the consumer unit it didnt trip, but we need to investigate this tommorow. Any ideas whats happening. I know the purpose of a rcd is to monitor the circuits it is protecting and turn its self of if it notices a difference in current going out on the line and back on the neautral of 30mA or more.
Of the top of me bonce, assuming a newly installed circuit.
Visual checks (usually done during construction if working alone).
End to end continuity of conductors, using either R1+R2 method or wandering lead method (favour the first as you'll get polarity as a side effect).
Insulation resistance testing of conductors for final circuits
Polarity checks.
Then on to live testing:
Live Polarity Test.
Ze, current tests, Zs.
Then on to RCD/RCBO tests
and finally functional testing.
In practice for an existing installation you'd normally check Ze, PSSC etc
you missed out the wet finger test! :crazy:
doe anyone want to expain it for a simpleton. Ie go into cosumer unit and put in a temporary link between the circuit ur testing and the earth bar. get ur meter and put it on low ohm resistance setting. null leads. test between line line and cpc at each point on that circuit.
ps. as its a dead test does that mean i can get away with just tripping the main switch, or will i be best of fully isolateing things and tracking down the source which feed the consumer unit and turning that of... I think i would sooner do this but if its not necesary (sp)?
Trust me....and do as TQ suggests mate as if you want to get into inspecting and testing then GN3 is the way forward....
Hi lofty84,im a bit worried as you have described yourself as a simpleton!!!!!!!!,now for reasons of safety if you feel that you are not competent to do testing then maybe consult your supervisor,you may be joking about your competence or then again you may be a fully qualified but alarm bells are ringing.Im getting the fact that things were just switched on before testing,the old bang/no bang method,am i missing something lol
Reply to Tripping RCD in the Australia area at ElectriciansForums.net
Thank you for taking the time to help explain this - much appreciated
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
