davesparks
So the overheat protection is operating, what logical process did you follow to arrive at the conclusion that it needs to be replaced?
Is the I/H the only source of heat? is there a solar heat input of some kind, bearing in mind the recent hot weather?
Has someone turned up the temperature on the stat?
Have you measured the temperature of the stored water or the temperature at the thermostat?
Has there been an increase in demand for any reason recently?
How old is the stat?
