tripping times? | Page 2 | on ElectriciansForums
Discuss tripping times? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Could be right there.
I always thought it was 40ms @ 5x because that's a fifth of 200. 300 is just confusing!
If we stick to the 200ms, least we'll be edging on the safe side. Though I can't recall seeing one above 54ms in my limited time of being let loose with an MFT (and that turned out to be my winky connections!).
The 40ms at 5x stayed the same, don't understand why they changed the 1x to 300 really anyway as its not 5x40 which made made sense before.....the 5x test is the only one it has to pass anyway I seem to recall, although I would be changing the Rcd if it failed 1x anyway
i also have had over 100ms trip times before on one side of the cycle usually.
Reply to tripping times? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
I believe you're in Australia? Could you clarify the distribution arrangements - is this RCD for one particular circuit, or is it protecting a...
Yes Table 3A that was in Appendix 3 of the 17th edition of BS7671 and in BS 7671:2018 (Blue Book) up to the release of BS7671:2018 +A2:2022 (Brown...
