Trouble-Shooting 2x18W Flourescent setup | on ElectriciansForums
Discuss Trouble-Shooting 2x18W Flourescent setup in the UK Electrical Forum area at ElectriciansForums.net
Edinburgh
I agreed to take a look at shop sign for a shopkeeper friend. The fitting apparently stopped working form one day to the next. I have checked the following.
1) 240V getting to the fitting.
2) Both starters work fine in another fitting
3) Buzzed all the way round wiring loop with tubes/starters out, and no discontinuities.
4) Owner has bought new tubes
When nothing worked after all these tests, I recommended he pick up a replacement ballast. The original ballast was model; Tridonic ATCO EC 36 A502K. These are discontinued, so the local supplier recommended an alternative which I have fitted.
I'm wondering now if it's possible the tubes, may be a different spec. I'm assuming the recommendation of the ballast is correct, and that the ballast wasn't faulty when it arrived. Are there any addtional tests I can do on the circuit with prety standard multi-meter?
Hoping someone can give some more pointers to help with this.
Swap both tube and starter from a working fitting and vice versa if known good combination still doesn't work (assuming 230 volts at fitting) then dead test for continuity on all components i.e. live to ballast in/out, to starter in/out to near end cap in/out to far end cap in/out then to neutral. If all present and correct **** it and buy a new one!
if you do swap the fitting, an led panel would be a better choice, ledhut stock them and im sure your preferred wholesaler could get you them as well
Reply to Trouble-Shooting 2x18W Flourescent setup in the UK Electrical Forum area at ElectriciansForums.net
You really need an inductance or LCR meter or a ring tester which are expensive to buy but you can make your own ring tester if you want a project...
