Khuz360
Hi All
I have tried to wire in a doorbell and I'm having trouble getting the wire through the hole on the inside to the outside and vice versa. I know the hole is at an angle and no matter how much wire I feed through it doesn't seem to come out the other end. I made the error of pulling out the old wire prematurely.
I have tried to use a stiff bicycle brake cable to see if that will go but it doesn't and even went as far as trying to magnetise the brake through which also didn't work.
Does anyone have any suggestions on how I might be able to solve this problem without drilling a new hole completely.
The hole is less than 6mm in diameter.
