Hi,
I won't bore you with the back story, but I need some advice on how to connect a rocker switch for a Stanley Fatmax vacuum (please see photos below). It is meant to have three settings: Off, On, and On through the power take-off plug. Through a lot of trial & error (& tripped breaker resetting), I can get it to run in positions 1 & 2, and the power take off works in both, but it doesn't stay off until the tool plugged in is in use; instead, it runs continually in both positions.
Having tried to approach it logically, I thought that if I switched the wires around for long enough, I'd get it working correctly, but no joy after many hours. I need someone who's not a DIY muppet like myself to lend some advice
