Trouble with a florescent light | on ElectriciansForums
Discuss Trouble with a florescent light in the UK Electrical Forum area at ElectriciansForums.net
stu ledge
Hello electrical forum, long time reader first time poster, hope you can help me, I had been asked to change a single bulb to a florescent strip light with two tubes, I looked at the light that was in place and it was not looped so I assumed that the connections to the light was via a junction box and it was switched there and that I could wire this straight into this i.e there was a neutral not just a switch live, when wired in one side worked the other didn't, check usual things such as bulbs and starters, the wiring block on the strip lith had a L/SW AND L/UNI, I was wired into the L/SW which looked correct when looking at how the strip was wired but thought I should try the other side in case, this only resulted in the side that previously was not working to light up but not brightly and the side that was working not to light up at all, I told her that I though the fitting might be faulty and she is replacing it, now I am worried that I may have missed something and when I go back to fit it again it will be the same problem.
Any ideas would be welcome
Not really sure on that one, the dimly lit sounds like an emergency light running on batteries.
Are you sure that the correct ends were used for each lamp, i.e. one side of the ballast was feeding the same lamp
Lastly was the second lamp correctly positioned in the end caps.
The original wiring sounds correct but did you check for voltage just in case.
Thanks for the replies, I did check the wiring of the strip light it's self but it look fine with no indication of having a battery back up, the instructions made no mention of anything other than a standard L E N arrangement, and I did check as was getting a 230/240 volts reading, I am a little baffled by the L/UNI marking on the junction part and will have a look to see if I can find any thing on line to point the way.
At risk of stating the bleeding obvious, what did the wiring instructions/diagram for the strip say? What Zs (or R1+R2) (or R2) and IR readings did you get at the cable? Have you confirmed supply polarity?
Reply to Trouble with a florescent light in the UK Electrical Forum area at ElectriciansForums.net
https://www.nationallighting.co.uk/amalfi-gu10-6-light-spotlight-bar-dimmable-adjustable-matt-black?vat=1&gad_source=1&gclid=CjwKCAjwhIS0BhBqEiwADA...
Of course, showing my age now!
