I have a job of running a new cable to a DBB. The 16A MCB is in place and the oven is rated at 3.9kw so needs to hard wired. The customer has tiled walls and will not allow me to remove them to run the cable. He wants the oven switch surface mounted.
I have approx 0.5m of cable from DBB to the surface mounted switch which will be for the oven
The switch is a fair distance from the oven but what would you guy recommend using as trunking for a surface mounted cable?
