Try this ! | on ElectriciansForums
  • Thread starter daiplayer
  • Start date
  • Replies 17
  • Views 2K
Discuss Try this ! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
series...:-? ...pretty sure i got this wrong...if you know this...could you explain please ....:-?
I'm thinking... in series so current is same thru both
Calc Z using pythagoras =223Ω
calc current from I=V/Z = 0.89A
calc Vl = I x Xl = .89 x 200 = 178V
calc Vr = I x R = .89 X 100 = 89V
mind it is still very early for me lol!
ok...think we both got it wrong here. lol....i got Z= 223 ohm....therefore current (v/z) = 0.35A
Vr = IxR = 35.7 v
Vxl = 71.54 v ....?????
As a check try... Vs = √(Vl²+Vr²)
One of our answers works, the other doesn't!
guess whose works :cool:;)
Edit: 114 views so far no one else going to give an opinion???
sorry mate...the question was Vs 80v.....i wrote 200v on here. So i assume you are correct too !!! lol .
Guess that does kinda make it harder for me to get the right answer LOL
ah well at least you got confirmation of the method and i was at least able to think straight early on a sunday :D
not a lot of difference there, only a measly 120v. enough to run a sds drill on. no wonder answers are different.
pushrod, please xplain calculating Z by that old greek geek. done this theory once but it was 40 years ago.
Just about to post and i lost it all:mad:
easier to explain if i could draw on this
imagine a right angle triangle with long side (hypotenuse) of 5 and the other two sides of 4 and 3.
The theory is "the square of the hypotenuse is equal to the squares of the other two sides added together"
So 5² = 25
and the other two sides are 3² + 4² =25
In this case Z (the impedance is the hypotenuse) and the other two sides were R (resistance) and Xl (inductive reactance)
So Z² = R² + Xl²
and rearranged Z = √ R² +Xl²
Know any two and you can work out the third one
usually right angled triangles are all simple multiples of 3, 4 and 5
eg 6, 8 and 10; 9, 12 and 15 etc etc
(better post it before it all disappears again:))
Edit: The wiki explanation is a bit dry THIS is dead straight forward.
Reply to Try this ! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
And with a duff one, it just sits there, not knowing which way to turn, but drawing considerably more than its normal run current.
Ok so just done a quick test on mine. Megger mft on high gives 0.30 Robin 4120dl on 20ohm hives 0.22 Robin 4120 on 200ohm gives 0.28 Bearing in...
