Trying to install downlights into a room | Page 2 | on ElectriciansForums
Discuss Trying to install downlights into a room in the Lighting Forum area at ElectriciansForums.net
It's not 'just the wiring' the existing circuit needs to be checked to ensure that it is safe to make alterations to it.
The regulations have changed a lot and now require any new lights in domestic installations to have RCD protection so there may be additional work required.
[automerge]1599422644[/automerge]
What about RCD protection?
Assuming RCD protection is already in place.
Yes your part of the installation must comply to current Regulations.
I guess its just like adding a new socket, just seems a bit harsh.
However replacing an existing socket isn't.
What if the OP replaced the original fitting with a clik marshaling box, then its all plug and play?
Might be a struggle to get it through the downlight cut out though.:rolleyes:
Well if their approach to electrical safety, particularly protection against electric shock, is to look for loopholes and ways get of complying then they could probably do that.
Reply to Trying to install downlights into a room in the Lighting Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
My hypothesis was the clamp of the relevant MCB being outside of the prong on the busbar, but the lack of a CU sinks that theory. Is this all...
brilliant thanks for your support. Lee
