I
impactes
Hi al,l I am working on a tt system at present. I am going to be a adding a new d/b which will be ran from an existing board which has a 30ma main switch, controlling 1 other circuit i need to change the main switch to 100ma and the 1 circuit its controlling will need changing to a 30ma rcbo as its controlling outside power and lights.
The reason i need to change the main switch is because i will be using 30ma rccbs at new db.
The question i need answering is does the 100ma rcd need to be time delayed? If so the problem i have is that its a hager board and cant seem to find a time delayed rcd from them, so is there an alternative manufacture which i will be able to use? or do they do 1 and am i just not looking in the right place?.
Also would it be advisable to put in new earth electrode to supply new d/b current Ra 25.8 ohms.
Cheers
Cheers
