I was asked to find out why some sockets were not working on a temporary board today.I plugged my socket and see in and it came up with a N fault.The install looked rough to me but it is the first time i have been to a TT so i was a bit unsure. The supply neutral was seperate from the service head cut-out. It was basically a Tail block with a single earth connected into it,2.5 mm². No main earth terminal presentWhen i pressed the RCD it would not trip and i was reading a voltage between N-E approx 12 volts.U/U have been out and said that the supply is fine and that it must be something on the consumer side.Does this sound like someone has tried to convert the TT?I disconnected the consumers installation and told the owner of the flood damaged home to contact there supplier. They were non too pleased but i did not want to mess about with it until i looked into it a bit more.Anyone got any advice/guidance that they would like to share.
