TT Max Ze | Page 2 | on ElectriciansForums
Discuss TT Max Ze in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
can't go too deep though as the rod will melt when it penetrates the earth's molten core.
How would you know? You'd just keep adding more and more rods (as the end melts off when reaching the core) :D I guess your Ra wouldn't get much better though ;) ... back to work !
Reply to TT Max Ze in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
For what OCD? There may be other means of over current protection that allow a Zs of0.45 (HRC Fuse?)
