Evening guys, I've got 2 basement rooms that are being supplied from their own cu which is fed from a 32A MCB in a split load rcd board in the house which is a TT installation. The cu in the basement is relying on the CPC in the 6mm supply cable to the basement cu as its main earthing conductor. The cu in basement has a lighting and socket circuit. With no rcd protection but is rcd protected back in the house cu.Do I need to install a rod for the basement cu and does it need rcd protection?Thanks
