TT outbuilding | on ElectriciansForums
Discuss TT outbuilding in the UK Electrical Forum area at ElectriciansForums.net
grumpyjohn01
The Sticks, Dorset
Hi All, Just thought I would run something past the collective wisdom. Recently did a job that involved the conversion of a garage remote from the house to a small habitation space. The old install was supplied from the house via 6mm swa on a 30a BS3036 with the earthing connected to the house TN-C-S. I have kept that supply system but as the refurb included a kitchen with copper pipes and a steel supply pipe, I decided to separate the earth and fit an earth electrode. Of course I have fitted an amd 3 type steel ccu as the old board was in a dangerous state. I glanded incomer into plastic adaptable box and then fed the new ccu with a short length of 6mm T&E through back of box into wall void and then into ccu from rear through grommetted knockout. cpc of twin was terminated neatly into connector and L & N terminated into 30mA rcd mainswitch with minimal primary insulation exposed. Anything anybody would have done any different? Just musing as I fill in cert...can't think of a better way...anybody? cheers John
Is the gland of the cable within the adaptable box so it is contained from touch and the box identified. I would have probably used pvc/pvc into the CU so the cpc wasn't an issue. How short is the cable run in the cavity.
Thanks for reply. Yes box is identified and gland is external to box but has a very tight fitting shroud entirely covering gland. Yes, I would have preferred to use 6181Y but can't seem to readily find it in sizes below 10mm and there was no space to fit a bigger box to terminate a larger size so I thought a bit of twin was the best alternative...probably could have pulled the cpc right out as it was only about 300mm long. A pre amd 3 install would have been much more straightforward of course....!
Reply to TT outbuilding in the UK Electrical Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
