tt rcd or rcbo | on ElectriciansForums
Discuss tt rcd or rcbo in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
devlin maguire
Hi in aTT system can a rcbo be used as incomer instead of an rcd or should the rcbo be down stream of a main switch/isolator
Mac
Reply to tt rcd or rcbo in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Yes Table 3A that was in Appendix 3 of the 17th edition of BS7671 and in BS 7671:2018 (Blue Book) up to the release of BS7671:2018 +A2:2022 (Brown...
