Boys
I just looked at a TT system which comprises of a 100ma RCd which feeds a Service block, from the service block there are 3 sets of tails which in turn supply 3 x 30ma RCd's, these RCD's then feed 3 x CU's. The CU's are all type 3036 , what I want to do is change the 3036's to 60898's. Owing to the fact that the CU's are protected by a 30ma RCD will I have to go the whole hog and convert the Cu's to the latest 17th edition or will a simple swap suffice
