TT system do I need to fit a main switch or time delayed RCD switch? | on ElectriciansForums
Discuss TT system do I need to fit a main switch or time delayed RCD switch? in the UK Electrical Forum area at ElectriciansForums.net
baazab
uk
Hi everyone I'm ready to do second fix on a rewire it's a tt system all my circuit will protected by individual rcbos
Do I need main switch to be normal dp switch or time delay rcd please help.
if every circuit is protected by individual RCBOs then a main double switch is fine
Is the consumer unit fed by a cut-out ? Or a sub main ?
Reply to TT system do I need to fit a main switch or time delayed RCD switch? in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Try to keep this nice and short. Had an EICR fail on a health centre due to corrosion on main supply which was causing high Ze values...
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
