Discuss tt system in the UK Electrical Forum area at ElectriciansForums.net
can I knock 1 next to the 1 that's already there and link the two with 16 mmyou. well, at the customer's expense, of course. TT system earthing is the customer's responsibility. bang in a couple of 5/8" screwed together rods, at least 3 ft from the building.
rods should be spaced 1.5 x rod length. the existing rod is probably a 3ft. twig. depth is more important. i would start afresh with screwed rods. get at least 2m depth. and away from the builder's rubble that will be next to the wall.
try to miss incoming service cables/pipes/etc. LOL.
absolutely....and often overlooked....No1!! ....lol!!
As stated Depth is the key to roded TT installations, to ensure both it's stability and for enhanced Ra values... Also it's advisable to install a flush to ground concrete, or heavy duty plastic earth pit, (not one of those black PVC adaptable box things) for rod position identification and ongoing maintenance purposes...
ir they go for the `budget` option...and get one of those box cap thingys...that just perches pathetically on top of the rod.....totally unsuitable wherever theres a risk of damage to the rod.....
at the end of the day..this is the main earthing arrangements...so i cant understand why so little consideration would be paid to it....
so obvious ..I've only just noticed incoming earth only 10mm will 16mm bring it down enough
where have i mentioned here about increasing CSA of main earthing conductor in an attempt to get the Ra down?so obvious ..I've only just noticed incoming earth only 10mm will 16mm bring it down enough
no...that would consitute an earth `bonding agent`....think pat testers......a 10ft length od scaffold tube would make a good rod. get wade88 to weld a lug on it. don't let him glue it, though.
Reply to tt system in the UK Electrical Forum area at ElectriciansForums.net
