tt system | Page 2 | on ElectriciansForums
Discuss tt system in the UK Electrical Forum area at ElectriciansForums.net
neath
just done a new ring main on a tt system ..ze at source is 355..(r1+r2)= 1.3 ..measured zs at socket 296 still more than 200ohms recommended whos responsible for getting it lower me or the provider
the 5/8 rods screw together and are 5ft long, 2 of them together should improve results.
all depends on your outlook mon together. side by side or screwed. like the old lady who had 2 cats that died. with being so attached to them, she decided to have them stuffed. so she went to the taxidermist to instruct him. he asked her if she would like them mounted. " no thanks" she replied. " just put them side by side"
The last TT install like this i did the rod was totally corroded and pulled easily out of the ground. However the Zs readings were all quite low (about 40 ohms ). It wasnt until I checked the Ze that the problem became apparent and it was parallel paths through main bonds that brought the original Zs down.
So as a thought, Scott have you also checked and confirmed theintegrity of the bonding in this property as well?
you cant rely on extranious for Ze...
you need to get a stable Ra....and the only way your goin to do that is with several 5/8" rods connected together and properly sited...about a meter away from any building edges and foundation rubble.....
depth is key with TT
Glennspark, dont know if you misunderstood my post as I never said you could or should rely on extraneous metal to act as earth return. If i did that then why would I have bothered to checked the rod as the Zs were low anyway.
Without knowing the install i was just asking the OP if he had checked main bonds as he doesnt seem to have any parallel paths bringing down his Zs on his newly installed rfc.
Reply to tt system in the UK Electrical Forum area at ElectriciansForums.net
As previously posted, almost certainly due to differences in readings obtsined with high and low current measurements on the meter, low current...
OLDBOY
O
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
