Tv Aerial amplifier cable | Page 2 | on ElectriciansForums
Discuss Tv Aerial amplifier cable in the UK Electrical Forum area at ElectriciansForums.net
Leicester
daughter moved into a 1 bed rented flat for uni tv Aerial works in lounge but not in the bedroom feeds of 1 aerial it looks like landlord says she needs a cable that connects to the wall socket (bedroom) to tv with a little box attached to amplify the signal from the main aerial point in the lounge ..what's the cable called I'm looking for hope you understand what I'm on about people ....Thanks picture would be great
( tv works in lounge but not in bedroom says no signal
You need to be sure that the second wire goes to the bedroom and that it is terminated properly , and it has continuity.
You could connect it to the lounge out cable to see if that helps. Both cables could be amplified .
It is difficult to to know without seeing it as this could have been interfered with in the past , it is likely with it being student accomodation and the landlord seemed to know it was not working
Reply to Tv Aerial amplifier cable in the UK Electrical Forum area at ElectriciansForums.net
Not totally clear what cables are accesible in the loft, but ... Can you not just feed a permanent L & N from the switch to each of lights 2 and...
This fella puts his face to it about halfway through, he has an opinion on the very subject.
4K
