TV aerial help | Page 2 | on ElectriciansForums
Discuss TV aerial help in the Freeview and Terrestrial TV Forum area at ElectriciansForums.net
Dru
I am installing a TV aerial for the first time.
it is on a ground floor extension. They just want to be able to get free view.
As the main aerial is a long distance away I was looking to install a second aerial on the extension which would feed only the new TV point in the extension.
I was informed that I would just need to pull a coax cable from the new aerial to a coax socket.
I have done so, but when it comes to installing the aerial outside I can only find huge aerials to install, the same as the style you find on most rooftops, which is not what I want as it will be in the back garden and look unsightly.
The only small one I can find is a caravan style one which says it needs a clear line to the mast which isn't blocked by trees and I imagine this one wont suffice to get the full range of digital signals.
I have found a couple but they need a power supply which I never installed as I thought it wouldn't be required.
Does anybody know of a small one or have any ideas of a solution which doesn't involve extending the cable to the main aerial?
All help is very much appreciated as I am currently left with a cable at a knockout box and the other end hanging out of the wall with no solution apart from putting a massive oversized aerial in the garden
Lol I'm not going to be trying that don't worry. I've done a bit of research and have hopefully found a decent splitter that in going to try first. Should that fail then I'll have to install a socket and amp.
Reply to TV aerial help in the Freeview and Terrestrial TV Forum area at ElectriciansForums.net
well now to throw some stuff on the tv wiring I did ages ago I have a labgear 8 port distribution amplifier mounted in the airing cupboard...
3 core wouldn't, but 3 core and earth should I think. The live from the UH4 could feed both the brown and grey of the valve.
