tv aerial | on ElectriciansForums
Discuss tv aerial in the Talk Electrician area at ElectriciansForums.net
Hi
Its not something i do but got asked to look at some tv points what arent working.
Ariel in loft then goes to 3 tv sockets not far away about 25m run loop in out method but only 1st tv is working all cables look fine well parts i can see are anyway.
Does it need a booster so other 2 tvs work
If i was wiring it i would of took all 3 tvs back to ariel to a booster but was already done.
Any help
Cheers
Re: tv arielw
Hi,
Two things to try,
1) Try disconnecting both cables connected to 1st TV and plug cables through directly to 2nd TV and see if it gets a signal then.
2) Connect the core and earth of the cable from 1st TV to 2nd TV, then at the 2nd TV end of cable, confirm continuity of the cable between 1st and 2nd TV.
Reply to tv aerial in the Talk Electrician area at ElectriciansForums.net
I recall where a fluorescent capacitor would cause a separate socket RCD to trip when turning off the light
Ask your electrician when they do a site visit as to what is required they can also notify the installation to Building Control under Part P of...
