TV point question? | Page 2 | on ElectriciansForums
Discuss TV point question? in the UK Electrical Forum area at ElectriciansForums.net
Ross1
Evening Guys,
Ive gotta install 2 x TV points ( 1 in living room & 1 in master bedroom. My customer is having an areial outside the house for freeview. How do I link the 2 tv points back to the aerial?
Do I run 2 x co ax from a spliter in loft? or do I run 2 x coax cables from outside aerial? or do you get a tv point that I can connect 1 in and 1 out behind the point?
inexperienced when comes to tv, coms & sat etc
Please help
Hello mate as an aerial and satellite installer for the last 20 years,I can safely say that if you always run all tv/sat cables min rg6 quality back to 1 central location usually the loft you will not go wrong.As to weather you need an amp or splitter you won't know until the aerial installer has given you a correct signal level measurement.Hope this helps
Reply to TV point question? in the UK Electrical Forum area at ElectriciansForums.net
Thanks little spark. Good point but the drivers I'm considering have a sync and communication between driver function. So (as long as it works)...
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
