Twin and earth buried in concrete. | on ElectriciansForums
Discuss Twin and earth buried in concrete. in the UK Electrical Forum area at ElectriciansForums.net
R
Robo
Went to look at a kitchen refit today. Did a bit of investigation work and the kitchen appears to have a twin and earth buried direct into the floor.its rcd protect however in my opinion this is bad practice?
On another note iv got take a new cooker supply to annual and in the middle of the kitchen. I planned to do this in 25mm conduit buried in the floor.?
Another sparky has been on the job and done various alterations to lighting etc and hasn't put this on a rcd or certified the work.
Another sparky has been on the job and done various alterations to lighting etc and hasn't put this on a rcd or certified the work.[/QUOTE]
if its got additional protection...then whats the fuss?
caus he`s a bell end
i had a job at a builder freinds house --to wire a gas boiler to heat a pool
the boiler was situated in the garage he had built a cast concrete pool in the back yard and had wired the pool lights in twe
he just chucked the twe into the wet concrete when it solidifyed the cable destroyed itself as the concrete shrunk
what was the question?
you inspect what you can see.....you test what you cant...
That should get some special kind of award...
Mortar degrades PVC, so no, it shouldn't be buried directly in concrete. Very poor imo.
but kitchen fitters, plumbers, and builders should be ( buried in concrete, i mean )
It's an approved method in the BGB chaps - 108 rings a bell but I haven't got the book to hand so might be wrong on the number.
Reply to Twin and earth buried in concrete. in the UK Electrical Forum area at ElectriciansForums.net
