Twin & earth from meter to board | on ElectriciansForums
Discuss Twin & earth from meter to board in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Ross1
Hi guys, I've got a 6mm T&E leaving the suppliers meter and supplying an old 3036 wylex in front of me and the meter is sealed. Never come across this before. I'm sure the house can handle the load but is the twin & e acceptable?
Cheers
I can only assume that where the T+E is stripped to allow connection into the meter there are RED/BLACK conductors that are now as such non-sheathed cables that are showing and this is against regulation 521.10.1.
So apart from it being dog rough, unless there is a 40amp or smaller protection device, and whether or not the CPC is man enough, it is against the regulations.
No seals/seal on the cut out fuse ( 60A ) and like I said 6mm T & E supply from meter to fuseboard. Three 1,5mm/sq radials to lighting on different fuses. Two of them on 5A fuses with 15A fusewire in and the other one is on a 15 fuse. Talking to customer and she been there 5 years and never touched the board. Every day something new.....
Whatever happened to connecting your new tails to the existing and sending the supplier a application for connection form
The last I heard a few years back was that a £16 charge was made,is this facility still available?
I have seen this quite alot, 6mm tails T&E, i have also seen this in a fast food takeaway. There was no sign of burning on any of the connections. I was a bit surprised the first time i seen it. while where on the subject of cables sizes, I had a look at fault with a cooker two weeks ago, the cooker had been installed with 1.5mm flex, which burst into flames, the guy told me it had been installed just over a year. (installed by an electrician apparently who charged him £75)
Reply to Twin & earth from meter to board in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
