Two basic switch/indicator questions... | Page 2 | on ElectriciansForums
Discuss Two basic switch/indicator questions... in the UK Electrical Forum area at ElectriciansForums.net
Norwich
Hi Guys,
I've recently moved in to an upstairs flat and in the bathroom there is fused switch on the roof - which I have to turn on so that the extractor fan would come on... Can I remove the fused switch and fit a cord pull type switch? Any ideas why there would be a fused switch fitted?
Also, I have a shared staircase and at the bottom I have a switch that turns on a light in the staircase, in the lounge there is a double pole, single gang switch, one switch controls the staircase light. I'm wondering if there is a way to have some kind of indicator (red led etc) display if the staircase light is turned on - no matter which switch is used?
Thanks in advance
yeah I thought about pir, but he will still use it - sounds pathetic I know but he has an identical one - just I guess I pay for mine and he pays for his, so if he uses mine then its all good...
I'm thinking a test switch type thing with the little key haha....
Reply to Two basic switch/indicator questions... in the UK Electrical Forum area at ElectriciansForums.net
You only need to switch the lines and the contactor is rated per pole so for example a 16A four pole contactor would be fine.
Interesting document thanks. But it neglects the half-wave rectification, and also totally neglects the effect of the coil inductance when...
2 3
