Two radials together, when separated it trips dual rcd board. | on ElectriciansForums
Discuss Two radials together, when separated it trips dual rcd board. in the UK Electrical Forum area at ElectriciansForums.net
I have just installed a new wylex dual rcd board replacing an old memera 2000 single rcd. Whilst wiring in I noticed what was purporting to be a ring main was in fact two radials in the same breaker, no problem I thought, I will split them up, one on each rcd, however, having done that it will occasionally trip both rcd's, I have checked and I haven't got the neutrals round the wrong way, putting both radials on the same side cures the problem. I have yet to do all the testing required but I was wondering if anyone had encountered this before and what the problem was, presumably it is a neutral fault somewhere?
For info I am a Electrical Trainee and this will be checked and notified.
D2E
Are you 1 million percent sure its 2 radials?
That's a fair point, when I didn't get any continuity between the Lines I put in a shorting link form Line to earth and tested sockets round the house, one of the radials did one part of the house and the other radial the other half but I suppose if there is a break somewhere this is exactly what you would expect to find
Are you saying you didn't check the circuit fully and made assumptions before you altered the system and made live ?
D2E
Do you mean that you will be getting a part P registered electrician to check what you have done, then notify it for you?
With the greatest respect, I would advise you spend some time with an experienced electrician if you are new to the profession. What would you have done without this forum?
Reply to Two radials together, when separated it trips dual rcd board. in the UK Electrical Forum area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
