Two radials together, when separated it trips dual rcd board. | Page 2 | on ElectriciansForums
Discuss Two radials together, when separated it trips dual rcd board. in the UK Electrical Forum area at ElectriciansForums.net
I have just installed a new wylex dual rcd board replacing an old memera 2000 single rcd. Whilst wiring in I noticed what was purporting to be a ring main was in fact two radials in the same breaker, no problem I thought, I will split them up, one on each rcd, however, having done that it will occasionally trip both rcd's, I have checked and I haven't got the neutrals round the wrong way, putting both radials on the same side cures the problem. I have yet to do all the testing required but I was wondering if anyone had encountered this before and what the problem was, presumably it is a neutral fault somewhere?
For info I am a Electrical Trainee and this will be checked and notified.
D2E
Is this another teaser that we will never hear any more about. It does P***s me off just a bit when we never hear what the actual fault was. It could help us all.....you never know it could be a new fault that none of us have ever heard of!!!!!
Phil
By whom???????
No Part P registered Electrician can sign off YOUR work.
- - - Updated - - -
By whom???????
- - - Updated - - -
By whom???????
- - - Updated - - -
By whom???????
Reply to Two radials together, when separated it trips dual rcd board. in the UK Electrical Forum area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
